Use a super flow pump to empty a gastank???
ABOSS
I know this is a crazy idea but could i use the speare superflo pump i have to empty my tank before i drop it. i have about a 1/2 a tank left and from what i heard it could becoume difficult to move.
VermontTy
Support Our Troops
Re: Use a super flow pump to empty a gastank???
I tell you what, I'd steer clear of doing that. That pump probably has a run of the mill electric motor with brushes and things of the like. All you'll need is 1 spark in that motor to ignite the pump which will nicely catch your gas tank on fire, then burn your truck to the ground. Throw a quart of gas in a can, drive around your house until you run out of gas, dump in the quart and head for home. That's a much better plan.
ABOSS
I would normaly do that when i would drop a tank but my FP is bad. i guess i will use a hand held pump. I figured it was a sealed pump but better to be safe.
blk00z28
Forced to by choice
Or just drive around until the tanks somewhat empty (I know mine is DRY when its about a needle thickness ABOVE the E :roll: Dont ask how I found this out..) and then take it home, jack the truck up and remove the tank, it wont be to heavy if theres less then 2-3 gallon's left in it. Remember, at 16 gallon's, gas weigh's about 100lbs. So add the tank weight, and maybe 2-3 gallon's we're looking at what, 45-55lbs at the most. Not bad if you have two jacks or are willing to get under the truck without jacking it up. :)
