How much should i ask for it?
103 K miles or so.
I'd give it to him for nothing. That's what it's worth. It takes all day to change a converter if it goes bad. Which this one is about to.
At 103K, the converter clutch is about done. They wear out, like brake pads do. My experience is that a SyTy converter clutch is no longer working at all by 125K miles. I've had 3 with 125K that didn't work any more. The lining was worn out.
A reconditioned over the counter stock converter is about $70. Personally, I'd tell him to go buy a "nothing special" over the counter reconditioned converter and put it in. It will last for years in a stockish truck if it isn't flogged all the time.
Transmission frictions tend to go before the torque converter.
Correct. His point was that there isn't a lot of life left in that converter. They are basically throw away parts. You wouldn't buy a water pump at the junk yard, would you? Well, this is even worse because you have to R&R the trans to replace it.
Not to mention that unless you shut your trans off right after a catastrophic failure, the clutch material in the converter soaked in bad fluid, which can't be cleaned out.
What you have is scrap metal. If he puts it in his truck, he'll be pulling the trans shortly.
I have a used one that came out of Steve's (sel777) typhoon.. not sure of the mileage, maybe Steve will chime in.. but he needs it can have it if he pays the shipping...
