Using an INNOVATIVE DB gauge? STEP IN!!
TYTILIDIE
METH HEAD
Hey guys I don't know if any of you are using an Innovative DB gauge but I tuned a truck recently with one and found a few things out people should know. First off, I could not get the AFR in Data master to match the wideband itself. I programmed it the way we are supposed to for Code59 but still was always off under boost by 2-4 points. So if AFR's were 11.5 the gauge would show 9-7.4. Not good. I read on the Innovative forum that you can NOT program the LC-1 to any other than factory default when using the DB gauge. If anyone has info that this is not true I would love to hear about it but thought everyone should know if you didn't already.
0v=7.35
5v=22.39
Thats what you are stuck with.
I posted this on Code59.org too and thought I would post the info here as well since 59.org isnt "heavily traveled".
skwayb
NWSTP
Re: Using an INNOVATIVE DB gauge? STEP IN!!
I posted this on 59 also....
Well if that is true, you could use the Nonlinear (TABLE) - Generic/AEM WB table and put in all the values for each voltage between 0v=7.35 and 5v=22.39. Then turn off the flag for the innovate and turn the flag on for the Nonlinear (TABLE) - Generic/AEM WB. Then you can get them to match the gauge.
TYTILIDIE
METH HEAD
IC. Well, hopefully this information will be useful to anyone using that gauge. I was going insane with it until I finally found out about it on the Innovative forum.
It is a nice looking gauge and would love to trade my XD-16 out for it but I want to confirm that it can be as accurate first. The truck I am getting ready to tune also has the DB gauge so I will try using those settings and see how it goes. I'll let everyone know how it works out.
skwayb
NWSTP
Use these settings in Code59 and let me know how it works out. Some of the numbers for AFR are a little off due to rounding in Tunerpro. Let me know how close they are to your gauge.
TYTILIDIE
METH HEAD
Not sure yet. The truck I am about to tune needs a new balancer before I can set timing. Onve we get that done I'll check it out.
TYTILIDIE
METH HEAD
Paul, the #'s were pretty much dead on. I really appreciate the help.
turrrbo6
I am having the same issues with my innovate. My gauge and tunerpro are almost exactly 1 point off (gauge will read 13.5 and laptop 12.5). I did what Paul advised and no change then turned all flags off and no change. Anyone?
TYTILIDIE
METH HEAD
Are you 100% sure you are able to look fast enough to notice the change? I' sure you are but thought I'd ask. FWIW, Paul's settings worked great for ours. Maybe verify your LC-1 settings are correct as well.
TYTILIDIE
METH HEAD
Let us know what you find. While the LC-1 seems to perform well when it works I have had several issues with mine and others and will never own one again.
skipztt
boost
everyone i know who has a innovative, has problems with it.
trying to calibrate the wideband.. etc.. followed instructions.. nothing, changed sensors.. etc.. nothing still.
