vaccum hose ? HELP!
Sy0569
Ok guys, only one more hose to go and they're all finished. There is just one problem, I can't remeber where it goes!! Ugh.
It is the hose that mounts to, what *I think* is the cruise control accuator or possibly heater control? It is located on the driver side wheel well, in the engine bay, going into a cylindrical looking thing, with a moveable cable coming out of it. The vaccum hose comes out of the top. Not the best description I know, but I don't know what else to say! I know it is not the ball located under the battery tray. It's more "mechanical" looking. On the end of the hose it has what looks like a check valve with two exit ports. Thanks for any help you can give.
Ian Turgeon
Cascading Inspiration
correct, that is the cruise control. The line should exit it, go across the rear of the intake manifold and connect to the line that comes from the front of the intake manifold.
line: from intake manifold into a large diameter hard line that goes under the trottle body towards rear of truck. Tee off with a check valve to the EGR, then it goes into that large check valve with 3 ports on it. one of th outlets (sticking at 90 degrees out the side) goes to the cruise control. The other end goes to a T that runs to the vacuum ball and to the HVAC control line that goes into the firewall.
