I'm looking to get a factory vaccum line (hose) diagram for my Ty? The engine is going back in in a few days, and my mechanic wanted to make sure everything was in the right spot. Thanks for the help,
Lata,
Nick
Vacuum system consists of four different vacuum harnesses.
1) On upper intake manifold on the front side near the bottom there is a fitting screwed in with a hose barb facing the pass side. This is the main vac harness.
Soft straight connnector goes to hard line that makes a 90° turn towards back of engine. Connects to a rubber T that branches off to drivers side and back of motor. A two port check valve on drivers side brach and a three port check valve towards back of motor. Drivers side brach turns to hard line that goes to EGR solenoid on drivers side of motor and then from the solenoid turns to hard line back to EGR valve. Three way branch goes two ways. Towards back of motor it goes to a T with one branch to small hard line that goes thru fire wall to HVAC controls and other branch to soft line that goes all the way to front pass corner of engine compartment under battery tray for vacuum reserve ball. Other side of three way check valve runs to soft line that goes towards drivers side of motor to the cruise control vac canister.
2) On the back of the upper intake manifold near the top, there is a fitting that is screwed in with a barb that faces down. Rubber line to a rubber T that branches off to plastic line with one line going to the map sensor (drivers side of motor) and one line going to fpr (pass side of motor).
3) Off the drivers side of the intake manifold near the top. Large fitting with large vacuum hose that goes to the brake booster. This is where people have been getting boost source for boost gauges. (install kit available from RonG @ APE)
4) Off the bottom front of the throttle body. hose barb going straight down. 90° rubber fitting to hard plastic U to check valve to rubber line running past alternator to front drivers side of motor for the EVAP system.
