Vacuum Ball Line - WOT Sputtering?
Bustedsm
Numbered Car Crazy
I've recently changed the plugs, wires, and ignition setup on 1190 and after a week or so the truck started to sputter a bit in OD and I couldn't figure it out. Redid everything again, triple checked to make sure that everything "popped" into place properly and it still did it.
On the way to class tonight I ripped on it in second gear and the truck went insanely lean and started to sputter quickly, as if there was an ignition problem.
Now, I popped the hood and noticed the line from the vacuum ball underneath the battery has completely melted and split. I'm not 100% sure whether or not this is going to cause such a problem, but any other suggestions would be helpful!
-Chris
