vacuum block
atkonkler
Is this your bush?
I'm looking for a vacuum block....due to converting to hydro boost brakes I will no longer have a brake booster....If anyone has one on their truck and knows of a particular brand let me know....any info would be great on where and how much they would be....
Thanks Aaron
Re: vacuum block
What for? The line to the booster was a dedicated line, just plug it at the intake manifold. If you do attach a manifold don't forget it will also have pressure with boost so will require a check-valve of some sort and vac will be -0- when under boost. Maybe you could tie into the existing line where it goes through the firewall by the dist. That one keeps some vac due to the vac bottle.
HTH
atkonkler
Is this your bush?
Re: vacuum block
Qwertyphoon has a vacuum block for his because he has hydroboost....was just seeing if anyone had one laying around or where I could get one that will fit with little dinging around to get it to work. ...qwertyphoon says they don't make his particular block anymore.
