vacuum line changes...diagram inside
Ryda85
Senior Member
here is the normal vacuume diagram:
will everything work with these minor changes:
ZavzTy547
Senior Member
Re: vacuum line changes...diagram inside
SonomaGTlover said:
I second that... except for canister.
I should probably hook it up huh?
That's the correct diagram for the egr block off but I heard that your cruise control may not work properly without the canister.
On a side note, I don't understand the fuel vapor diagram..
Is the check valve in the fuel vapor diagram backwards?
Is the check valve suppose to only vent into the manifold but not vent back to the fuel vapor canister or does it matter?
Z
By canister I was talking about the vapor canister. Funny you mention it, I have never tried the cruise on my truck. It should be on the same system as the heater controls and the vacuum ball gives the necessary vacuum from reserve while under boost. Who's using cruise under boost anyway? LOL it's just for HVAC. I have a leaky dash panel so my heater/ac controls aren't working at the moment. I just have the line plugged under the hood. That's a project for another day.
The way I understand it, the check valves block the boost from entering the systems dependant on vacuum. To me it seems that the heater/cruise valve is backward acording tot he diagram. Maybe someone canverrify this? Since they are diagramed like arrows, don't they point to the direction of flow?
SEL777
One of 101
ZavzTy547 said:
That's the correct diagram for the egr block off but I heard that your cruise control may not work properly without the canister. Z
My vac line to the canister is not connected and my cruise still works. I have planned to do the mod the EGR delete and planned to route mine the same way.
VermontTy
Support Our Troops
Does the check valve in the diagram "point" to the direction that air is allowed to flow in, or is it bass ackward?
Ryda85
Senior Member
thanks for the help....goin out to go wrench a little
92TyLA
will this work?
You could say that the only thing "required" for proper operation of the engine is the line to the FPR and MAP sensor. Everything else is optional. Although venting the tank might be an issue.
I run almost that exact setup. Cruse control is deleted, and I use a home-made canister. No issues.
