Re: vacuum line off turbo?
No...your oil pressure gauge is fed from the oil pressure sending unit back near the distributor. There aren't any vacuum lines on the turbine side (rusty side) of the turbo. The is a coolant feed line (solid metal tube that goes over near the thermostat housing), a coolant return line (another solid metal tube that goes down to the passengers bottom of the block), an oil feed line (braided stainless line that screws to the top of the turbine housing) and an oil drain line (another solid metal line that goes down to the oil pan to let oil drain from the turbo.)
