Vacuum line on wastegate
Typower
It's not a jimmy!!!!
The rubber end that a vacuum line slides in to on my wastegate just broke off. Where can I get a replacement or how do I fix it?
Tooky
Serious about performance
Just run new lines.
[/list]
Falco
Get some kind of silicon lines. I'm using RS Akimoto lines and happy with them. Summit carries them. Get a whole kit and replace all of your vacuum lines if you are still sporting the originals.
HTH,
Typower
Thanks for the pic and suggestions! I think I will purchase the new vacuum lines and try to change what I can. I do have a rough idle problem so maybe I will kill two birds with one stone. Knowing me, I'll probably be back on here with questions once I try installing everything. Falco, is this the correct part number for the Akimoto lines you ordered from Summit - AVC-51006. Thanks again!
Falco
I like red. So I went with AVC-51004. :wink: On a side note I bought two kits. I guess one kit could be enough, I had plenty left, but I've no cruise controll, EGR, vacuum ball... So just order two of them if you wanna be on the sure side.
HTH,
manitoufs
For quick, cheap fix until you get the tubing, Pep Boys has small 90 deg. elbows. They are not direct replacements but can be made to work.
