Valve Cover Breather
tbauer03
TRBOBOX
I was just wondering what you guys are using for valve cover breathers. I went to autozone and they had like chrome dress up breathers but they were too big in diameter and hit the map sensor. I like the way those k&n breathers look anyone got a part number for them?
odium
1BADGMC
Have you had any problems with removing the driver side PCV valve? I have heard that removing the driver side will do something detrimental to the engine from reading backlogs on this forum, but any time I ask, nobody seems to know why or have experience with it.
How long have you been running the breather? Removing it would help remove the garbage building up in my intake...
odium
1BADGMC
Have you had any probs with the PCV valve removal on the driver's side? I still haven't gotten any answers.
SeattleSy#1255
Category 5 Conservative
No, had mine for 4 years now and others who have had it longer. The answer is simply, No.
SY2932
Administrator
Zero problems for me since I installed a breather on the driver's side valve cover. This is true of ALL the other owners I know who have done the same as well. Keep in mind that the connection on the driver's side valve cover is NOT a Positive Crankcase Ventilation valve but, a VENT hose. The other end of the hose attaches to the side of the airbox so, by installing a breather there you aren't doing anything to it that it isn't already doing. It simply allows fresh air to flow into the crankcase to purge out the vapors.
"Driveability and emissions 4.3L turbo (VIN Z) Section C13 PCV".
As far a reducing the amount of "sludge" you get in your intake, it will remain about the same since you aren't *really* changing anything.
tealty
Yeah it says that is a clamp on or something, but it gets pushed into the holes rather than being clamped on. I havent had any problems with mine. THe only side effects are.......a clean and oil free intake/TB. Just take a look at the lot of cars out there that are normally aspirated and end up getting turbo charged/SC. They dont throw on a pcv system.
later
Jordan
I disagree about disbaling the PCV valve system (passenger side system, I have a drivers valve cover breather) My corvette's SC did have provsion for both boost and vacuum systems and many of the other systems for the Corvette at least had PCV systems that operate under vacuum. Just because an aftermarket part doesn't include a PCV system, that doesn't mean its best For engine life. Every factory car I know has a PCV system. Many race cars have this system (though many don't use intake vacuum), PCV isn't an emissions add on, it adds life to the engine.
Everytime your piston compresses the air fuel mixture, some of it leaks past the piston rings. Fuel, air, condensation end up in your crankcase (below the piston/combustion chamber in the oil cavities) The PCV systems remove the excess air pressure, gas fumes and condensation. If you don't have a PCV valve systems, the piston have to do the work of removing the excess air pressure (ie robs a small bit of hp and put more pressure on the piston rings in way they weren't designed) The gas and condensation have no way of easily escaping as except through evaporation.
Now having said that, I have no idea how much engine life is being sacrificed by disabling the PCV, I have never heard any one losing an engine to a pCV removal. However, I go through great length to keep my engine operating in top condition and spend a bunch of money on synthetic oil and high end oil filters, keeping the PCV valve system is a no brainer. Plus I have alky to help clean out the intake anyways.
tealty
Agreed it does take away a little hp, so i'll just add .5 lb of boost to compensate. Yeah most super charged kits have pcv provisions. Im just talking about the do-it-yourselfer who just bolts on a sc or turbo and adjusts the fuel/timing to make it all work. Besides, ive never read anywhere about someone's engine failing due to not having a pcv system. I believe the reason its on stock vehicles is for emissions and the reason its on high hp cars with a true vacuum pump is b/c they wanna get every little bit of hp outta there setup. THe epa is ghey. BTW, i too have alky.....and I still dont want oil vapor running through my engine. If my engine blows due to no pcv system, I will let everyone know. :)
later
Jordan
