valve cover questions
flintdawg
i havent gone to put my valve covers on my vortec heads yet but i have heard that when you switch to roller tip rockers you have clearance issues with the valve covers.....after searching and calling a few places i have come up with nothing except for 1 set that is sold by a board member. i didnt really want to drop $275 for just a set of valve covers....what other options do i have....or what is everyone else doing? i am using comp cams 1.6 roller tip rockers...am i going to have this problem....thanks
myclone
Copy and paste of a PM when I checked into the same thing.
To: myclone
Posted: 12 Feb 2003 03:32
Subject: Re: valve cover spacers
Well i dont actually have a set of the spacers, but they are available from Mach Performance. There website is www.machperformance.com. I think they run around 120 a set. They are about 5/8 of an inch tall and work really well if you want to keep the stock plastic valve cover.
The ones that i am having made are an adaprter to go from the center bolt style to the perimeter bolt style, just like they already make for the small block V8, only mine will be for the 4.3, the apadter will be 3/8 thick, I am using a gm performance parts tall steel valve cover, that i am going to have powdercoated, maybe silver along with the upper and lower CPI intake and then i am going to paint the bowtie and chevrolet script on the top of the valve covers red to macth the red and silver vortec plastic dress up piece that goes on top of my upper CPI intake.
Hope this helps you out.
Mike
Falco
I'm not sure, since I'm using the Edelbrock valve covers, but as far as I remember you shouldn't have clearance problems with roller tip rockers, just with full rollers. If you do a little search (didn't work for me with more than one word :-? ), you might find a discussion or two regarding to this...
HTH,
The valve covers clear a full roller rocker on Vortecs.
It takes two simple tricks:
1. Take a grinder or dremel and gently massage underneath the plastic valve covers. If you have an old one to practice, you can determine how much to remove before breaking through. These are still cheap from GM.
2. Use a old style cork gasket glued to the new style rubber. Thank BG for this tip, as his original gaskets are still sealing an engine after many years. We bought new plastic valve covers, since his were cracked. We then copied his grinding technique, and reused the old cork gasket.
Lynn D. Brown
Valve covers
Valve covers
Mike F.,
I presume U have the plastic Vortec Covers and don't have your old stock steel covers ? I understand that the stockers fit and the plastics don't. Anyone else know differently ?
I am staying w my stockers and have been assuming they will fit w my 1.6 Crane Golds and Hi Lift cam. I should be finding out in the next few weeks.
jwaller
Evil Genius/SyTy Guru
a stock cover will work with any rocker. the plastic will work with roller tip only. beyond that you can mod both to clear anything either.
Pittman
I agree with John Waller. I have the stock valve covers with crane gold race with no issues on vortec heads.
Lynn D. Brown
The stock SyTy heads come w stamped steel covers, which will supposedly fit any of the roller rockers. I will know w my Comp Cam Rollers on Vortec Heads within the week. The late (96+) Vortecs come w plastic covers which supposedly have more problems. Hopefully U saved your stockers ?
spooldup
Super Member
my stockers are still on my ty right now so i guess i'm covered. That's cool that we can reuse them. Thanks
Lynn D. Brown
Yeh, I was even thinking of chroming my Valve Covers (VC), but i'm not sure that it will even show up on our machines ? I've had my engine apart 4 a year, so I don't even remember what it looks like.
From what I remember and my pictures, U can't even see the Pass side VC, and U can only see part of the Drivers side VC.
spooldup
Super Member
I can see the entire driver's side cover and part of the passenger. I am a polishing freak so as long as i know it's shiny i don't care if you can't see it. :-?
FLSY2730
I have vortec plastics and never had any problem and i have 1.5 and 1.6 roller cranes.
Now i have mike lees alum. bad ass valve covers that i still have not put on and had to modify the drivers side with a 200 amp altanator, had to cut a 45 on the front , all is good now but i just dont want to put the on till everything is perfect with the truck because it is alot easier to take off and on the plastic valve covers.
FLSY2730
BigAl... said:
BTW the valve covers that Mike sells cost $285
I know I just bought them.
BigAl...
Al, we are going to have the same trucks pretty much, alot of the same parts anyway.
What did you do for a turbo and transmission?
What are going with on the tire and wheel combo?
How soon before your up and running, we will have to get together at moroso.
