I had some local guys here in Dallas say the same. However they all said it really depends on spring, lift, rpm.
Jerry, and some others on here run without Dampers.
What do they do exactly? Stabelize the valve train to the steap onset of a roller cam lobe???
I wonder if you can buy dampers seperate?
Damper failure is what started a big'ol problem in my truck. The dampers on three valves broke and destroyed the seals and sent shit all over the motor.
