tbauer03
TRBOBOX
Ok i went to the machine shop today and dropped off some parts and they didn't like my selection of valve springs. It wasn't something i gave much thought about and i need to do something about it. I figured i could use Comp Cams Conical Valve Springs 982-12 and have a good stock upgrade. But they said that they would not use something with 281lbs open and recommended some springs with at least 400lbs and they recommended springs designed for lt1's to take advantage of the roller cam, lifters, and rockers.
Basically i am running a comp 422 cam, comp 850 roller lifters, Crane 1.5 self aligning rockers. and i have a set of comp 7808 pushrods but i am probably going to need to get some stronger ones when i go to stiffer springs.
What Springs and pushrods should i buy?
Oh and they are going on to vortec heads.
Thank You in advance.
