Fighting5thSVT
I have just recently done this and a few people have been PMing me asking me some questions. So I figured I would throw this up here. This is the first time I had done a repair like this, so if something is inaccurate, please chime in and point it out. I have no problem with that. Feel free to flame me too if I really did something @ss backwards.
First off, this was a somewhat long and redundant type of job. I have the luxury of my Typhoon NOT being a daily driver, so that was a huge relief. I could work on it and do 2 or 3 cylinders at a time and not have to hurry. If this was my daily driver, I would commit an entire Saturday (if not some Sunday morning) to it to assure that it was done right and not rushed. This was a learn-as-I-go type deal for me. Obviously, it got easier as I progressed and learned what worked and what didn't. This is how I did it and what I learned...
Tools
The special tools you will need are as follows:
1. Air hold tool
2. Special valve stem pliers and installer (both GM 4.3L Specific)
3. Valve spring compressors. I used 2 of them. The first one is the standard Craftsman one. It has the handle. It was decent to use at best, however DOES have the staggered arms at the bottom making it easier to use. I'm sure there are better ones out there. The 2nd was the generic Autozone one. That was needed to do the cylinder closest to the brake booster. There is no way you can get the 1st on in there. This one I cut the handle off of and just used the 3/8 ratchet attachment. This one DOES NOT have the staggered arms at the bottom and was a challenge to get to grab the springs just right
[/IMG]
The Valve seals I used were from HoodTuned. They were the Viton Fel-Pro seals. The intake ones are labeled intake/exhaust, but should only be used on the intake. They resemble the stock ones you are removing. The Exhaust ones are labeled only exhaust on the box. They are a hard plastic with rubber inside.
[/IMG]
[/IMG]
Tools
1. Air hold tool
