Valve train setup help needed for ported L35 heads
QuinnSY
Well, I have been indecisive about what brands and models of the valve train components I am going to go with on my build, and I need to order it all yesterday!:lol: Anyways What I need.....
1. Full roller rocker arms at a 1.5 ratio
2. Stronger than Factory push rods
3. Lifters (with tie bar?)
4. Quality double roller timing chain (not chinese crap like a lot I have seen)
My camshaft lift specs are
525 valve lift intake
510 valve lift exhaust
and I forget the exact spring pressure right now, but I think I remember it being 120lbs on the seat and 350 closed. I will get back with exact #'s tomorrow.
And my heads are ported L35's if that changes the opinions of valvetrain components.
I'm not looking to skimp on quality or price to an extent, so give me your thoughts opinions and of course criticisms! :D
Re: Valve train setup help needed for ported L35 heads
That looks good to me.
My L35 heads have 1.480 springs around 110 lbs on the seat and 330 open and around .580 max lift. Studs are pinned, the ports cleaned up, and they have a three angle valve job. valves were new GM parts. 412 cam. 1.5 roller tip rocker arms. I used the stock push rods (not like Im using crazy spring pressures). Comp High Energy Roller Lifters. Im not very impressed with these lifters. They pump up loud. RPM told me they would be that way. Its my fault for not listening. Everything seems good so far. I coupled that with at bigger turbo and my top end is double what it was. 375 awhp @ 22psi. I think I should be around 400 whp at 26psi. Should be close to 500hp at the motor.
Does this help?
QuinnSY
Yepp It helps thanks! What would have you went with for lifters knowing what you do now?
And also I want to go with a full roller rocker arm. anyone have any they swear by?
Thanks!
Quickstop [UK]
Combating adversyty.
I bought 875s from RPM and two of them were bad. I hear other people have had problems with Comp Cams. (Search for my thread on lower intake assembly and diagnosis)
I put the stock GM lifters in and they work well. CC have a quality control issue apparently.
:2cents:
:2cents:
I read your post. So did you have bad lifters or were they out of adjustment? Mine are just loud when you first start it. They take a bit to pump up and stop being noisy.
Quickstop [UK]
I think they were bad. When I pulled them out the engine, 10 were rock solid and two were springy = not pumping up.
The ticking noise was consistent and now and again another ticking noise appeared which I attribute to the other lifter.
I did adjust them by 1/4 turn initially by mistake when CC say 0 to 1/8th but that should have destroyed all of them, not two.
I haven't had my truck out the garage since I got the new ones in but I think the noise has gone. It's hard to tell with the hood off and in the garage.
I'm sticking with the bad lifter theory as others seem to have had similar problems.
QuinnSY
Ok, so after some research i ordered the Scorpion narrow body series. Seems like it will be more than sufficient.
and am still looking for a suitable lifter. It sounds like you guys have had bad luck with comp lifters so what have you guys found to work well?
Thanks
