Bad Ass Black Trucks
Finally getting time to work on my motor and I keep running into problems.
Basic info for this problem: Balance shaft block, with L-35 heads.
I have a set of self aligning, Crane Gold Race 1.6 rr's from another project that I am trying to use on this build. The heads use screw in rocker studs (not sure if L35's came threaded but mine are). I located the rocker studs and guideplates (to use as spacers) that other guys on the forum have used in the past.
I took the time to use a pushrod length tool and select the correct length pushrod in order to have the rocker sweep across the center of tip of the valve stem. Like this:
It came out to a funky 6.9" (Comp 7631) but I went with it. It is shorter than stock which is 7.1" if I remember correctly. Stock is on top, Comp on the bottom.
I cut down the guideplates today and went to set things up. Unfortunately, I ran into several problems. #1 the Pushrod looks to be hitting the head in the dinky passage down to the lifter. :squint: Why the hell is it so small? I didn't notice that problem with the pushrod length tool.
Oh, I visually verified that the cam was on the base circle for these photos. Photos were taken at zero lash.
I guess I could grind away at the passage to make some clearance, but the heads are locked down on cometics and I really don't want to pull them off or have to break out the die grinder and shop vac.
Problem #2: The poly-locks hit the body at 0 lash with the 6.9" pushrods. :rant:
We're looking at the rocker on the right in the above image.
I'm guessing that longer poly-locks are available? I definitely won't be able to use stock valve covers with this setup now.
For curiosity's sake, I grabbed a pushrod out of the old motor and:
The pushrod clears the passage in the head to the valley and the poly-lock has enough clearance to go to 0 Lash plus 1 turn.
Well Crap! I could get stock length pushrods, but the geometry on the valve will be off! Here is a comparison picture. 6.9" Pushrod on the left and Stock on the right. The stock length pushrod puts the rocker at the middle of the valve stem and it sweeps over near the edge when the cam actuates the valve.
I am not dead set on using these rockers, but the cam is barely better than stock. I do have a set of 1.6 roller tip rockers somewhere. I guess I can see how things look with them sometime soon.
Anybody have any suggestions?
Other questions:
-What size is the -AN fitting that feeds the turbo oil?
-What size is the turbo oil drain fitting in the pan? The pan I got was tweaked when the fitting was removed. Need to try and clean out the threads with a tap.
-My engine is internally balanced, will a stock damper be okay to use? I have a stock one in good condition.
-I bought an ARP Balancer bolt, 2.47" long (Under Head Length). It was too long for my crank. Is that weird? My stock bolt is 2.2" long when measured with calipers.
-I got the wrong balance shaft timing chain cover (too new). It has fewer bolts than my block has. Think it would leak where the block has a hole and the cover doesn't have a fastener if I tried to use it?
Thanks to any advice you guys can give! I'm getting frustrated.
Other questions:
