Variable Water Injection....Very Interesting...DIY
Guys
I found something very interesting to improve a water injection system. This is a DIY website and it shows you how to build a controller that will turn on water injection based on the load the engine is under(MAP Sensor)
Read the website over for more detailed explaination and let me know what you guys think. This seems like it would end the need for multiple jets to be triggered at differant boost levels.www.autospeed.com/cms/A_1539/article.html
This website has some crazy shit all DIY, and cheap to make. Im thinkin about getting a subscibtion. Give me some feedback.....
Fern Sy#477
InvisiBill
Using this module to control an intercooler water spray is much cruder than the approach that we have covered in our Intelligent Intercooler Water Spray series, starting at "Intelligent Intercooler Water Spray, Part 1". For a high quality spray, we would strongly recommend that earlier approach - it will cool more efficiently and you will use far less water. However, the Intelligent Intercooler Water Spray Controller is also a more expensive product than the speed control module that we are covering here. And as we've said earlier in this series, building this module will probably cost you less than using even a simple adjustable boost pressure switch and relay!
Also, they charge $3 to view the article online...
Tydriver
TurboLS6 Powa'
Well I can see 2 possible issues with that article:
1. It appears that they are using a windshield washer pump as the primary source to send the fluid to the intake system.. I wouldnt feel real comfortable trusting a $3 washer pump motor for my $3000+ engine. (yes I realize a fuel pump isnt much more, but I'd bet it has a longer life span and can develop more pressure).
2. Varying the voltage to the pump may reduce flow VOLUME but I'd be willing to guess its also going to reduce PRESSURE too.. And less pressure would lead to less ATOMIZATION.. Right ????? I'm just thinking outloud here and wondering if there are merits to that setup. I like the idea and the thought process is good, I am just wondering if it would REAP benefits. It seems to me that the concept is good, but my primary concern would be ATOMIZATION at the lower speeds......
Todd, I was thinkinh the same thing about the whole pressure issure when the voltage is dropped to the pump??? But it seems that if the pressure issue wasnt a problem that this would allow you to run a larger jet for very high boost, and still have good performance at lower boost without bogging. Can anyone confirm the pressure issue??? Fern Sy#477
