Verifying of 3bar MAP, boost gauge, alky.
While waiting for my TC to get here I got this hair-brained idea to check if everything which is reading manifold pressure is reading correctly. No pics but they wouldn't help anyway. Here's my setup.
FIRST turn the alky system off! Safety first.
Using my cyl leak-down tester from Harbor Freight (which is no good for that anyway) I plugged the low pressure port leaving a HP gauge and a good regulator that works well at setting and keeping air pressure in the 0-25 range.
Next I rigged up a gaggle of fittings that allowed me to connect my regulated supply with the line off the back of the manifold (FPR and MAP), my line to the boost gauge in cab, and a third gauge. (Harbor frieght tool gauge, gauge on adapter and boost ga in cab.) This gives me a tripple check on accuracy. If one is wrong I'll see it. With only 2 gauges, if they don't match which is it?
OK, start feeding some air. 10# they all match. 20# 2 outside match, panel gauge is maybe a pound light. At 25# it was definitely shy a pound but I don't go there, just checked it.
OK good. Time to fire up DM and see what it says. Only way I could think of to test the MAP. After getting nowhere I learned that you have to use this sequence: Run up whatever pressure you want, Start logging of course, now turn the key on and see what DM says.
If it matches turn the key off and test a different pressure. What I found was once the key is turned on the MAP reads once and stays there. Presumably telling the ECM local pressure. It won't change until the motor is started. I doubt it will start with the ECM thinking it already ha 20# of boost...:rotf: Anyway not necessary.
I checked 3 pressures again. 10#, 20# & 25#. MAP via DM was dead on. Glad to see that.
Next up was checking when and by how much alky comes on. Using a different adapter I rigged up a high pressure ga to the alky line, removed the nozzle from the TB and rigged up a catch can for it. Not good to fill the motor with alky or burn the building down. Next came experimenting. Slowly bring up pressure and see what happens. With my OLD Julio Don setup all worked well. Turn-on around 4# with 2 volts going the pump. Nothing comes out. The pump makes a weird noise but isn't turning yet. But start bringing up pressure and you can watch it start pumping and increasing from there as "boost" increases.
The one thing I did see and don't know if it's normal or not was at higher outputs there is a LOT of pulsating. As it gets worse you can't read the ga, needle is going nuts. I'm assuming that it's because of the way the pump works. It's basically a 3 piston pump. More accurately a 3 chamber wobble pump. (My terms BTW)
Anyhow an interesting day at the shop. The TC was waiting for me when I got home.
LMK what you think of this "project."
TYTILIDIE
METH HEAD
Re: Verifying of 3bar MAP, boost gauge, alky.
I think its a good thing. I myself have done things like that several times for "curious" reasons. I used a vacuum pump on my MAP though. For the pump, what kind of pump is it? A Shurflo pump pressure should stay pretty consistent and not pulsate, your spray should be even and smooth.
Alky control uses a duty cycle to control the pump, so that is why it making funny noises when it first turns on and vibrates when running.
Thanks for the info. It was nice to find out that everything is working correctly. I've been thinking of doing this for awhile. Got-er-done.
