Verifying TDC...more info please.
Syclone#1992
SyTy.net Moderator
Get a piston stop and verify top dead center. The balancers with the timing marks on them have been known to slip. Rotate the engine each way until cylinder #1 touches the piston stop and make a mark on your balancer. The ½ way point between those two is the correct timing mark. Set timing to zero degrees with the Tan wire disconnected
How much is a piston stop? How do I know mark the balancer? I set the timing but I just want to verify it is at zero. Any tips/tricks apreciated. I hear timing has a lot to do with knock retard.
TIA
Falco
I got mine from Summit (CCA-4795) for $13, but I'm sure you can find it at any Auto chain store. For marking I've used a marker pen. Turn it over by hand in both directions still it hits the piston stop, scribe two marks. If the original mark is in the middle of your two then you are all set...
HTH,
