very lean & sputtering while brake torqing**fixed**
cvcsmkr
i have what was told to me was a 50# ultimate bin.
stock motor, stock tranny, using tunerpro w/ostrich.
while i brake torque the engine sputters and my afr's go as high as 20.
if i just wot while braking my afrs are 16.
but in part throttle like getting ready to launch it sputters real bad.
what do you guys think mechanical or is it in the tune?
if tuning which tables should i fool with to correct.
SBNova
Re: very lean & sputtering while brake torqing
Try changing the VE tables, in the areas where you have the problems. If you make VE changes with little or no change to the AF ratio then you probably have a mechanical problem.
cvcsmkr
the only table i tried to change, was f29c.
i could see the cells being accessed.
but then i reaized thats the closed throttle table.
i had the 2 rows of 50-60 map values starting @ 60 and going to 100 @ 1600 rpm.
it made almost no difference, but i dont know if it should since its the closed throttle table?
should i fool with f29?
Tooky
Serious about performance
If you got the tunerpro/ostrich combo working (sounds like you do), just go ahead and try changing F29. Hell, zero the whole thing out while the engine is running. See if it stalls. You need to verify that your changes are really having an effect. Took me a while to get that going on mine, due to several bizzare issues. Once you know it's working, you can restore the chip to normal settings, and then start adjusting F29.
Although if your truck is acting in the manner you describe; I'm thinking you either have a severely mismatched chip/injector setup, or more serious problems than just a little out of tune...
cvcsmkr
thanks for help guys.
i solved problem by adjusting F29 in the appropriate areas.
