Ok, before i left the States and moved back to Sweden i did search every where for any information in this subject. I search the internet and i search the bookstores but i could not find the answers i was looking for.
I have the Turner RT, Romulator, WB O2 and a bunch of BIN files that i got from a few very good and helpful fellow Sy/Ty owners, you know who you are
Thank you very much for sending me those.
But i want to start making changes myself not reliy (spelling) on others all the time. I will not start doing changes or make my own BIN files until i've learned at least the basic in why and what to change in these tables?
Some of them i already know why and what, but others are like Grek to me and i don't even know if i should make any changes in them? I put a * on tables that i know so anybody that would take the time to explain these for me know what i know :-?
Tables
ECM Switch Table *
ECM Constant Table *
Main Spark Advance Vs. RPM Vs. MAP *
Cool. Temp. Compensation Spark Vs. MAP
EGR Spark Advance Vs. %EGR
Power Enrichment Spark Advance Vs. RPM
Start Up Spark Advance Vs. Coolant Temp. *
Spark Adv. Correction For Premium Fuel Vs. MAP
Boost Spark Advance Correction Vs. MAT Vs. Boost
Knock Retard Attack Rate Vs. RPM
Knock Retard Recovery Rate Vs. RPM
Idle Overspeed Spark Retard Vs. RPM Error
Idle Underspeed Spark Advance Vs. RPM Error
% Volumetric Efficiency Vs. RPM Vs. MAP
%Vol. Efficiency Vs. RPM Vs. MAP (Closed Throttle)
% Volumetric Efficiency Adder Vs. RPM
Desired Boost Pressure Vs. RPM Vs. TPS *
Target Idle RPM Vs, Coolant Temp. (In Drive) *
Target Idle RPM Vs, Coolant Temp. (Park/Neut) *
IAC Initial Motor Position Vs. Coolant Temp. *
IAC Initial Position Decay Interval Vs. Cool Temp.
Power Enrichment Air Fuel Ratio Vs. RPM
Accel. Enrichment Vs. Differential MAP
Accel. Enrichment Vs. Differential TPS
Accel Enrich Multiplier Vs. Coolant Temp.
Accel. Enrichment Multiplier Vs. RPM
Injector PW Compensation Vs. Battery Voltage
Initial Value of Wastegate Duty Cycle Vs. %TPS *
Turbo Transport Lag Coefficient Vs. MAP
Turbo Transport Lag Coefficient Vs. RPM
Base Pulse Constant Vs. Desired %EGR
Decel Enlean Coolant Factor Vs. Cool. Temp.
Decel Enlean MAP Contribution Vs Delta MAP
Decel Enlean TPS Contribution Vs Delta TPS
Decel Enleanment Multiplier Vs. MAP
Crank AFR Vs. Coolant Temp.
Cold Engine AFR Vs. Coolant Temp. Vs. MAP
Cold Engine AFR Vs. Coolant Temp, Closed Throt.
TCC Lower Load Limit Vs. MPH, 3rd Gear
TCC Upper Load Limit Vs. MPH, 3rd Gear
BPW Boost Multiplier Vs. MAP
EGR Duty Cycle Vs. Normalized EGR Valve Flow
Desired %EGR Vs. Vacuum Vs. RPM
EGR Flow Pressure Compensation Vs. Pressure
Another thing i was wondering, in the ECM Switch Table shoulden't i uncheck the EGR Diagnostic (error 32) and EVRV EGR Calculation Enabled if i have removed my EGR valve but have the electric part of the EGR system intact??
I would be so thankful if i got some teaching in the Tables and values.
Thanks,
Tables
ECM Switch Table *
Thanks,
