Very rough idle, Wb lean, and more "datamaster log inside"
Pull a sample from the tank, put it in a glass jar and let it sit over night.
The water will sit on the bottom, so try and get your syphon hose towards the bottom. You could also pull a sample from your fuel filter, should have been changed already. I change fuel filters every other oil change with a wix filter. Don't change your fuel filter until you confirm the fuel is good.
I can't remember what ohms the ECM coolant sensor should be. It's either high when cold and low when hot or vice versa. Just check it on your datamaster, it will be noticeable that the temp is off if the sensor is bad. That can cause fuel distribution problems, especially in open loop.
