gjp
another post whore
I have noticed that my truck makes a whining noise. Sounds like its comming from the trans while in park,N or D. When I rev to 1500 I get a vibration in the cab. i checked the flywheel runout while it was out. I cant remember what it was but the post from george blacka while back said it was ok but boarderline. There is no cover on the Converter. Is it a normal sound to hear. I tried to record it but its hard to hear it. The vibration could be from the solid mounts?? I have yet to be in a car with solids mounts but it vibrates a lot more then stock. Idleing I just hear the noise. I pulled the converter by hand to the flywheel and hand tightened the bolts then torqued the bolts. Should I recheck the flywheel and what is ok as far as measurements go. And if the flywheel is bad can it be removed while the engine and trans is in. . Thanks
