cloneman315
i got another email on this yesterday,might want to put this in the vault
It takes about 10 min ,and the injector drivers are not on the ecm b fuse they are on the ecm 1 fuse.Here is how you wire the relay ,terminal 85 runs to ground terminal 87 gets fused constant 12volts from batterey terminal 30 goes to the ecm side of the cut pinkblack wire and terminal 86 goes to the car side of the ecm cut pink black wire.
