WyoSyclone
Well, I've been tuning with Code59 for quite a while now and have run up against an issue that I'm wondering if anyone has seen before.
What I'm experiencing is almost like a high RPM flameout... I've attached a jpg that shows what I'm talking about... as the Sy is accelerating the RPMs (top red line) are stepping up and down with the overall increase in engine speed. This 'wavering rpm' covers about 75-100 rpm. This issue is REALLY holding the truck back from making some good runs.
In this image you can see where ignition voltage (flat blue line), Injector DC, and BPW are all inter-related with respect to the wavering rpm.
Recent new items are: NGK ur6ix's gapped at .028, new cap and rotor, new ignition module, new Accel factory-type coil, new Magnecore wires, new alternator.... I've taken every B+ and ground wire in the engine compartment and taken it off, burnished it with my dremel tool, reconnected with star washers where needed.
System voltage during a run: between 12.9 and 13.4
Fuel pressure: 48psi while sitting (I don't have my cab-mount FP gauge installed yet).
AFR's in the above frame ~11.4
Boost only ~12psi on this run with "0" WGDC
My theories:
1) The truck really doesn't have a 255 pump in it like I was told it did, though I would think BPW and Inj DC would be higher if it were running out of fuel.
2) The RPM Stage1 is moving enough air that the turbulence at the outlet of the internal wastegate is great enough to be causing back-pressure spikes.
3) Partially clogged CAT may be causing back pressure issues.
4) ECM going bad?
5) Some other electrical gremlin.
Has anyone else seen this same issue?
Thanks for any ideas you may be able to offer
My theories:
4) ECM going bad?
