volvo fan wiring
graham1524
Well-known member
I'm in the process of wiring the fan in. I'm going to wire it into the intercooler relay with its.own relay. But can that work if I hot wired my intercooler? I'd like to see how some other people did their relay and made it work. I've been doing a lot of searching but found no info of wiring the relay.
Thanks, graham
Flyin Ryan
hated cuz he drives fords
Re: volvo fan wiring
Here's what I used for mine.. The part where it says the thermostat or temp sender is where I connected the IC pump wire. I used 40 amp relays and haven't had an issue in years
graham1524
Well-known member
I like this. But two questions
1) Does the IC switch go to the relay for the intercooler pump?
2) I cant run the ic pump hotwired or the fan will always be on right?
graham1524
Well-known member
I'll bring this thread back, I've been looking at the following thread
http://www.syty.net/forums/showthread.php?t=50097&highlight=volvo+fan+controller
Its been very helpful but I cannot figure out exactly where I am wiring the switch. The last post on the thread says not to use the IC relay but the IC switch. What switching source am I supposed to be using? And again, I have my IC pump hotwired, will this cause an issue with the fan??
Thanks, Graham
graham1524
Well-known member
I have an idea. I re-read your post. I think you're planning on using the ECM for fan control. But you want the IC pump to run constant-on. Ie, "hotwired". You can have both. Here's how:
Cut the yellow wire at the IC relay.
Connect the 1/2 of the wire that goes to the IC relay to ground. The IC pump will run in IGN at all times.
Using the diagram below as a reference, understand that terminals 85 & 86 are the relay coil. These two terminals consist of the "control" portion of the relay(s).
Connect 85(s) to the yellow wire at the IC relay that goes to the ECM.
Connect 86(s) to the white wire at the Wiper motor.
Terminal 86 will be B+ (hot) in RUN or ACCY, but not in START.
Terminal 85 will be grounded by the ECM when parameters are met to do so.
HTH
DaveP
Thanks Dave That is exactly the response I was hoping for
Graham
