Vortec 772 parts
Andreas
Gone put my Vortec's, casting 772, on my Ty this winter. Actully I gone keep the stock valves and springs for now.
Have been reading posts about rockers, lifters etc.
Seems like the steel Comps cams 1,5 is the way to go with 415cam.
1. Arent the 1,52 the easiest choice, since they are self aligning? (no guide plates needed)
But it doesnt says non OR self aligning on these 1,5 ones #1101-12 http://www.compperformancegroupstor...C&Product_Code=1101-12&Category_Code=V6ROCKER
But it does say self aligning on the 1,52 ones #1317-12 http://www.compperformancegroupstor...C&Product_Code=1317-12&Category_Code=V6ROCKER
Which rockers is the preffered choice?
The studs for these full rockers are ARP #100-7201, right ?
2. Are the wideboby rockers ok with centerbolted valvecovers
TYHOGG
Re: Vortec 772 parts
I'm using the comp 1.52 self-align rockers, but i just changed out the spring kit on my 772's.
Stock valve srpigs will bind with a .500 lift cam. Your really going to need new springs (most likey ratiners), pushrods and lifters to run a .500lift cam.
Andreas
Thanks for the input.
Damit, the shopping list just gets longer and longer :lol:
I'm not sure about the pushrods lenght...
Push rods, Comp Cams #7372-16
Length 7.800 ???
http://www.compperformancegroupstor...e_Code=CC&Product_Code=7372-16&Category_Code=
#COMP-982KIT valvesprings kit with oil shields #COMP 4703-16
http://www.compperformancegroupstor...e_Code=CC&Product_Code=982-KIT&Category_Code=
http://www.compperformancegroupstor...e_Code=CC&Product_Code=4703-16&Category_Code=
Lifters COMP-875-12
ViciousV6
400HP/550FTLB
I was using the 422 cam and then a custom cam. Best springs i bought were the LS1 # cca-26918-12/ cca-774-16 retainers/ 1805 i think was the push rods, with high energy lifters with Crane Gold 1.6 self aligning rockers.
Ralph
went 11.3 on this combo.
Andreas
Ralph
Thanks Ralph, I will look into them.
TYHOGG
If you don't want to have the spring seats cut down, use COMP Cams 982-kit. I'm runnig them on my vortech setup with stock length pushrods and 422 cam with no problems. Usally pick it up for around $130 incl. Springs, retainers, locks. Will work on the stock valves too.
