A
amerimuscle99
Guest
I am doing Vortec heads and have a couple questions. I'm also doing a mild cam.
Can I use stock head bolts? Found some on Summit for $14 a side. Also found stock head gaskets for $25 a side. This would all be temporary until a new motor is built and that's why I think it will be ok. I want to get the vortec heads and cam in to play around with tuning before the new motor. I have read that stock head bolts and stock head gaskets have gone pretty far. Just don't want to shell a bunch of money into the stock motor.
Also does anyone have a recommendation on a good machine shop in Colorado Springs. The vortec heads I am getting super cheap. They need to be cleaned up and gone through. also need the intake holes drilled and tapped.
Thanks
Thanks
