GM tech
I should start with my parts:
Vortec Heads,Crane Powermax 2020 cam,S/S valves(stock diameter),comp lifters,comp pushrods,comp spring kit,RPM roller tip rockers(1.6),arp screw-in studs.All parts from RPM.
My problem is when I try to adjust the valves.I take it down to 0 lash,I start to do my adjustment in 1/4 turns and the valve opens as I'm tightening.The intake and timing cover are off,the lifter is not taking the adjustment.I checked the service manual and it says 2 ways of adjusting
ress-in studs,0 lash + 1 full turn.Screw-in studs,torque to 20ft/lb.
Why can't I get my adjustment right??
I've got a set of factory Vortec screw in studs with a shelf,but my rockers and hardware won't fit.Can I make these work with a different rocker arm??
Truck is down and I need it,any advice is welcome.
