Vortec Head Valve seals?
Sean Krupa
Moderator
Can anyone suggest what type of Valve seals I need to run? I just bought a set of Ported Vortec heads that were used on Ed Hess' truck. Here is some info on them. I don't know if the Valve guides are OEM or different. I PM'd Jwaller and Ed hoping they'll reply.
Ed Hess Vortec Heads information
Casting # 12556140
Heads are modified with 7/16” Screw in rocker studs.
2.02 Intake 1.60 Exh Valves
Spring are 150 lbs seat pressure with a 370 lb nose pressure.
Thanks,
2.8-350TBI
Re: Vortec Head Valve seals?
Best thing to do would be to remove the spring and seal thats already on there and then measure the vlave guide o.d. and order seals acoordingly.
On my vortec heads, I am going to a standard sbc valve stem seal. od on valve guide just needs to be turned down my machine shop. Its free anyways since the machine shop cut down the top of the guide down for more lift clearance and their arbor has the standard sbc for the valve guide. Vortec heads have a slightly bigger od on the valve guide than standard sbc's
