Vortec "how to" site?
Captain Morgan
Moderated User
I remember back in the day there was a site that showed exactly what needed to be drilled and what needed to be welded on the heads and intake for the 96+ conversion. Does that site still exist?
I figure if Im gonna "attempt" to do this conversion this year, i need to see how much i can do in house and how much i cant.
thanks in advance for the help.
The best way IMO is the welded lower, and redrilled heads.
Redrilling heads is easy.
Welded lower is available through McCoy from me on exchange or send in basis. You can call McCoy for pricing and availability.
It isn't that big of expense really, considering the advantages to them.
Zac
How much of a chance is there that the lower intake will be destroyed? I guess what I am saying is, can the welding of the lower permantly warp the Intake rendering it useless?
Welding does warp it, but I machine the surfaces flat afterwards.
What I have noticed is the welding doesn't warp it anymore than a stock intake is NOT Flat.
I have yet to ruin one or even come close myself. Several other people (Waller, Canadian guys, etc.) have and do welding also and I haven't heard any issue there either.
Zac
Excellent. That put's my mind to rest a little about modding the Lower! ::thumbsup::
jwaller
Evil Genius/SyTy Guru
I've converted prob 2 dozen of these intakes now and the intakes are worse off before the welding than after. only about 10 thou is taken off to get 99% of them back to straight.
AXXE
I had my vortec conversion done by DL Auto through the Mike Renz GP. Manifold looks great. It is not on the truck yet if you want to take a look at it. Nobody has had any problems with them. Contact me if you need their #.
100in6
100in6
morgan
something noone has mentioned is if you do the vortecs you have to either machine the hole for the distributer down or use an adjustable collar on the distributer itself with the vortecs and make absolutely sure that the distributer goes far enough down so that it will spin the oil pump. i don't need to tell you what happens if you don't.
mike and john... when you are doing the intakes are you rebunging and changing the injector locations as well as matching the ports?
les
MikeRenz
not stock
les,
not moving the bungs at all, and doing no port work. That would be a lot more work - and a lot more $. The bungs actually end up being closer to the center of the head ports than the stock heads - so i don't see a need to move them.
as for the distributor hole....if you aren't using spacers between the intake, then there is no need to use an adjustable collar or machine the hole down.
100in6
100in6
yea mike, my intake is all hogged out and the ports are rebunged and some other changes. it came that way from stokes. that's why i was afraid to have it welded. just too much money in it to take a chance, and i don't know anyone that is a good enough aluminum welder that i would trust. i've seen an intake that you had your friend do and it looked really nice, but i was just afraid to take a chance with all the bucks that are in mine. my intake actually sat too low so the only options were to add material or make spacers. do the bowtie blocks fit a little different? anyway, i run with a bunch of guys that have big block stuff and they do spacers all the time so i had some cut on a cnc machine and then felpro gasketed each side. the spacers can be cut different thickness and felpros comes in different thicknesses too. i've run em up to 30 pounds of boost a time or two and never had any problems. one thing i can tell ya is gluing gaskets together DOESN'T work :( at least not for me.
100in6
100in6
100in6
100in6
hamrhead
After a year, I finally gave up on the double gastket thing, as well as the gasket/billet spacer/gasket approach, and sent my Lower Intake to McCoy for the welded up version. I'm tired of my anti-freeze slowly disappearing, and this last time the intake was 'whistling' at idle - sucking air I suppose? Anyway, hopefully the new one will be here in a day or so and I can bring the truck back to life again. :D
TYPHOOL7
Post Hawk
ive heard that with the 96+ you have to heavily modify the intake, while doing so you take a risk of having it not match up properly, or leak, due to the warping or what have you. Along with that, isnt there an adapter used between the intake and the head or is that what has to be modded? Hey i have pontiacs and a brodix, it dont match up perfect, o well, whats a couple of milimeters.....LOL
JUST USE 95's!!!
jwaller
hey les when you do it the way I do, mike's shop and the way JS does it for mccoy you dont have to machine down the dist collar. you only do that when using spacers.
I also include all the port matching and hogging with all of my intakes.
