vortec options
alaskan
i am going to put a motor together for my typhoon, the direction i am leaning right now is to rebuild the shrt block and go with vortec heads... BUT i live in juneau alaska and there is noone in this town that does anything close to that kind of machine work and i don't have the facilities.
what are my options?
this will be about a month out before i pull the montor and get started, is anyone selling a set of heads that are already machined? is there an intake manifold out there that will work for vortec heads without building an upper plentum? can i buy an upper plentum to work with some other complination?? any thought would be great guys.
Quickstop [UK]
Combating adversyty.
Re: vortec options
www.raceprovenmotors.com sell everything you need.
I am in the UK so in a similar position - isolated from the main SYTY vendors and parts.
You can buy a lower intake on here for around $300 or so and ship it to RPM (or just use your own one) and they will do all the fab work.
The vortec head package is very good (you need rockers though) and comes with all the porting/matching etc. It is an easy way of doing it although it isn't cheap - you're probably looking at $3000 all in if you go the RPM route. For me it was a no brainer and I am pleased with what I got.
Tooky did a thread on the vortec upgrade but he did all the work/hunting/parts matching himself and had access to machinery and stores. His result was good also and much cheaper but then he had everything available to him.
I would say RPM and Tooky are both at opposite ends of the spectrum - self help vs pay and relax.
:D
Good luck!
vortecfiero
Re: vortec options
depending on your build.. the early vortec heads flow better than the stockers
and are bolt on with little or no mods.
alaskan
Re: vortec options
i don't have to modify anything to fit early vortec heads?? i thought they had a different bolt pattern for the intake minfold??
vortecfiero
Re: vortec options
im using an early vortec cpi L35 engine with the stock syclone intakes... they bolted
right up.
92TYPHOON937
Re: vortec options
ho do u know if it is an l-35 head cuase in a local junk yard there a a shit load of s-10s bet one could have them maybe???
Re: vortec options
One way to tell if the heads are L35 is to look a the intake ports. The will have a hump on the top of them if they are L35's.
92TYPHOON937
Re: vortec options
i know where i might be able to find some but a picture to show me the differences would be nice so i can tell
4C FED
Absolutum Dominium
Re: vortec options
See the semi-circle (hump) at the top of the intake port?
That is unique to the L35.
92TYPHOON937
Re: vortec options
ah sweet thanks man next time i make it to the yard i'll look for some in the specified year ranges there
SY2455
70's Veteran
Re: vortec options
In addition to this, Didn't all the L35 head have the screw in rocker arm mount do to the higher RPM that they were built to run at?
SY2455
70's Veteran
Re: vortec options
Sorry, I don't know how I miss it.:doh:
By porting the L35 head, Is it possible to make them flow as well as vortec heads that are unported?
