vortec swap
alaskan
threw a rod through the in my typhoon. i scored a motor out of a 98 astrovan. not exactly sure what all i need to do the swap. would appreiciate ideas. also if you have parts for sale to go with the swap post them up please
NecroWolf
lost marbles member
Re: vortec swap
you will need the 4x4 oil pan. if your engine doesn't have the cast aluminum pan you can use the one you have, you'll need to het your intake welded up, redrill the intake holes on the heads and seal the stock holes. you might need to relocate the knock sensor but that about covers it.
Re: vortec swap
I posted a response yesterday to someone looking to use a Vortec shortblock (ie san the heads) and I have a thread in the Member Project of my Truck/ 03 Vortec swap.
alaskan
Re: vortec swap
i got the oil pan. the van the motor came out of was an awd van. what i do relly need is an intake manifold that is machined for vortec heads. also when removing the balance shaft you remove the old bearing and then install a new set so that the oil passages are plugged right? is there anything else??
NecroWolf
lost marbles member
Re: vortec swap
if you take out the balance shaft i think you need to find some freeze plugs to go in the block
Re: vortec swap
I left the balance shaft in.
jwaller
Evil Genius/SyTy Guru
Re: vortec swap
I've done this swap for lots of customers. lemme know if I can help.
