Vortec Valve Covers - Vendor?
hamrhead
Anyone know where I can get a set of these? One of our vendors perhaps?
And are these a Direct Replacement for the stock valve covers, or do you need to reconfigure the PVC pipe/valve and oil fill? Are they Stock Height as well, so no interference problems?
OR, any other valve cover options for Vortec Heads? Preferrably NOT chrome - PITA to keep clean.
I'm just tearing down the engine to replace the head gaskets, and my chrome valve cover 'covers' are rusting. Hence, they look like dog crap.
I'll do a search if I have to, but right now I'm in a hurry.
Thanks!:D
scotts4
ADDICTED
Re: Vortec Valve Covers - Vendor?
i have a set i just took off my motor . i am putting rpm valve covers on it . let me know if you are interested . i dont remember what i paid but was not that much new
VermontTy
Support Our Troops
I got the plastic "Vortec V6" covers off ebay for around $40 shipped, new with bolts and gaskets.
jwaller
Evil Genius/SyTy Guru
if you dont get them from scott's I have several sets of them now.
hamrhead
Sorry, should've asked this in my first post but,
Will they work with Kenne Bell Headers?
My stock valve covers just about touch the header on the driver's side, so now I'm somewhat hesitant to try plastic covers if ya know what I mean.
jwaller
I wouldnt use a plastic cover with KB headers. it's asking for a fire.
Syclone#892
You could get the edelbrock elite valve covers. I think there around $90 from summit but there aluminum and look good. 4cFed had them and I bought a set but I don't think I have any pics of them they aren't on my current motor. The only problem you will have with them is they have some plastic bolt look a likes in them to make it look nice around the edge and the kb's will melt them. you could just take them out and I bet find some bolts or just leave them out. Hope that helps.
mrweelr
Would ATR headers be just as likely to melt the composite ones? Also, are these a direct "bolt-in" replacement for the stock metal ones? I'm thinking about buying the set on eBay.
Ian Turgeon
Cascading Inspiration
RPM sells some aluminum valve covers, but there not as easy (or as cheap) to bolt in as the stockers. Im sure you wont have an issue finding stock black ones around here.
mrweelr
Well, I try to replace heavy metal pieces on my Sy with plastic ones, where prudent - saves weight. The prices for the Vortec covers at http://gmpartsdirect.com are as follows:
Driver GM #12554256 $24
Passenger GM #12554257 $24
Oil Fill Tube GM #10207349 Not in Stock
Oil Cap GM #10108694 $3
Seems reasonable enough. Wonder where I could get the fill tube? What about the bolts, do those need to be ordered separately?
scotts4
ADDICTED
mrweelr your pm if full pm me back about the valve covers hows 30 shipped
hamrhead
Thanks for the info and all the replies guys. I think for now I'll just polish-up the ones I have. After I get the head gaskets done and the truck running good again, then I'll take the time to look for a nicer set.
mrweelr
Scott - I'll take 'em so long as they aren't warped, cracked, and the seals are still good. Also, are you including the filler tube and cap? My inbox is cleaned out now, let me know.
ghettosled
SYTY SUPERSTORE
fyi, the newest design of our valve covers is quite a bit different then say the first generation, and some of the earlier ones.. Install is now much easier with deeper grooves for the gasket, and a tapered edge on the header side for improved clearance with KB headers, and the brake booster. Also we eliminated the notches for the accessories for a cleaner look. Either way with a physically taller valve cover, installation is obviously going to be more difficult then the short stock one.
As for the ATR headers, they go down instead of up, so you wont have the header practically touching the valve cover problem that common with the KB's.
vortecfiero
interesting side note
when i purchased my cpi "almost a vortec" the valve covers were missing the
seals and the the long bolts. The parts guy at the dealership mentioned that
it was cheaper to buy the valve cover assembly which included everything
I needed and the valve cover too rather than ordering just what i needed sep.
craig
