Re: Vortec Valve Covers With Spacers
There is more than one way to skin a cat. The problem with using .500" bar stock is while that would work great for the straight walls, what are you going to do about the corners? The radius on the corners is much larger than what you can get with two pieces of .500" coming together perpendicular
... I am no stranger to working with 1.0" X .500" bar stock. These are two clamp frames that I had to make for our thermoformer at work. That represents over a months worth of work...
You could get it done with precision machined bar stock and RTV in the corners IMHO. No welding required. Any amount of misalignment would be compensated for by the seal cord which you can get in various diameters, shapes and hardness. Bottom line is if I was going to make spacers, I would simply nest probably at least half a dozen of my block off plates in the center that would be cut out. That material wouldn't be wasted, would serve a as means to hold it down for cuts on the opposite side and reduce part cost due to less waste. But, that's the 11+ years of being a tool and die machinist talking :lol:...
