walbro check valve?
nallj92
ive had the pump in for about a year or so, got it from mike lee, Fuel Press drops as soon as the pump stops priming, drops to 20psi and then stops, checked FPR and thats good, injectors are not leaking, so that leads me to believe that the valve in the Fuel Pump is bad, from my searches i found that i can fix a fallen out valve? or is it just something where i have to replace the pump again?
jwaller
Evil Genius/SyTy Guru
Re: walbro check valve?
just replace the pump again if it bothers you that much. then again the check valve going bad doesnt hurt anything anyway so whats the big deal?
ghettosled
SYTY SUPERSTORE
you probably installed it with the stock pulsator instead of replacing it with the provided rubber hose.. Either way what does the FP matter if the pumps off anyways? As long as it holds pressure and supplies the fuel under throttle i wouldnt bother touching it..
