Walbro Fuel Sock Problem??
crazy151drinker
Well first off I would like to give a big Thank You! to all the people on this site. Without this site there is not a chance in Hell I could have changed the fuel pump.
Well now the problem LOL.
Truck will not run. After I switched it I turned it on and it fired right up- ran for a couple secs and died. Now it just cranks but nothing.
The Walbro is buzzing like a champ so I know its on.
The tank however is making some wierd sounds.
Im wondering if I put the sock on wrong and its not allowing any fuel to get in.
I noticed the old sock (which was pure black) was kind of "puffed out" ie it had some volume to it. When I put the new one on it was perfectly flat. So Im thinking the sock is stuck to itself and thats why Im not getting any fuel.
Either way im going to have to pull it out again, just thought I would pick your brains first. Its 110 outside and im on concrete so im going to wait a bit to cool down.
Thank you,
AJ
Edited to Add:
Well im on Crack. I thought I was hearing the Walbro. It was my Johnson IC pump and the gurgling was the intercooler :) So that means the Walbro isnt working.
Just in case it was a power issue I ran the Racetronix fuel harness to the Alt. Still no noise. Nothing from the tank.
Maybe I blew something.
I dont see how I could have misconnected the Walbro- I mean its only one connection.
I'll look at it again tommorow.
crazy151drinker
Re: Walbro Fuel Sock Problem??
I'll check them tommorow, im staying away from the truck ;) Would the Walbro have blown a fuse that quick??
crazy151drinker
Ok I followed this link (did a different search)
http://www.syty.net/forums/showthread.php?t=36039&highlight=fuel+fuse
Did the "jumper from the 12V block to the fuel pump prime connector in the same mess of wires (single gray wire with black plastic tab). If your pump comes on, the pump and wiring are good, and you've got a bad fuse or relay" and the pump came on....sooo
now im checking the other things :)
Thanks again :)
Update: Blown ECM B fuse. Trucks now start :) Tommorow i'll finish up the Racetronix and put it all back together.
