I just bought a 92 ty that is in need of a fuel pump due to slight overboost. would this pump solve the problem? what else do i need to change? The truck launches hard then sputters off after about 3500rpm only on hard acceleration though
I dont think the pump will fix the boost problem, but something you should check is you base fuel pressure, it should 43-45psi. Im sure one of the experts will chime in here in a few minutes.
Yeah, check and Replace the Vacuumlines.
Take a look at the wasgate solenoind, (the thing bolted on to your turbo)
and see if everything is conected and had no leaks.
you get a check engine code when it begins to sputter?
