Walbro info
Flyin Ryan
hated cuz he drives fords
Was researching some install info for my mustang... and came across an interesting write up especially since the walbro 255 pump is the most common pump for these trucks.. that is always the reason why I choose to post it up in this section of the forum and not off topic but if it has to be moved by all means
http://www.fuel-pumps.net/walbro-forgeries.html
ghettosled
SYTY SUPERSTORE
Re: Walbro info
i bought mine from rpm, so i know it is real, or at least hope
Our pumps are genuine Walbro, and purchased through the main North American distributor.
One seller on ebay now advertising a genuine walbro pump was the same seller who introduced the knock off walbro a year or two ago for half the price. Unless you read the fine print of his ad, you probably would have never known the difference.
I am not saying he is selling these knockoff pumps as genuine Walbro, but judging by the price something doesn't add up.
SloGN
9Sec Alky V6
Re: Walbro info
The Walbro 255 fuel pump that has been a common failure in the turbo buick community is the one with the markings F20000169. It seems that the GS340 series pumps are not affected by the defects from what some of the vendors are stating in the buick world.
I have had 2 of these pumps fail in the last 3-4 months The guy i was getting them from was buying them direct from walbro themselves
The Pump in my Talon Tsi just got to where it wpuld act like it was running out of gas and die and not start back up till the pump cooled off a bit.
The pump in the GN didn't fail like that it just got to where it was not keeping the delta pressure up when under boost and it costed me a set of headgaskets:rant:.
Some of the buick guys have been using the Toyota Supra Mark IV denso pump with good luck.
HTH
Pat Broughton
B
BoostedGMC
Guest
Re: Walbro info
Damn, I just put one in my truck. I really wish I knew that before hand. What a pain in the ass it was to install that tank.
ghettosled
SYTY SUPERSTORE
Re: Walbro info
FYI, for atleast the last year or two we have been making our own version of the 340M, which consists of a modified 340 pump not the F2 pump. Racetronix also does the same, so if you purchased a pump through either of us you should not be effected by the recent F2 model failure/recall.
Re: Walbro info
My Walbro has been in for going on 3 years and still pumping away. I'm actually more concerned with the "pulsater" bypass hose deteriorating.
