Walbro pumps
Foot Performance
Re: Walboro pumps
Re: Walboro pumps
I think that link is the right pump the 255 comes from a flow rateing I belive and the one in the link shows a 255 Litre per Hour so I am pritty sure that is what you want someone correct me if I am wrong
Re: Walboro pumps
Re: Walboro pumps
Yes you want the 340 listed in the link. It's the correct high pressure 255L Walbro for a SyTy.
ghettosled
SYTY SUPERSTORE
Re: Walbro pumps
the 340m was discontinued and replaced with the F2. Many people like Racetronix will machine a standard 340 pump to accept the correct filter and provide a wiring harness for a direct plug in, thus creating their own 340M version. Nothing wrong with this.
berzerker
wookie
Re: Walbro pumps
the only thing u have to do to get the 340 pump to work is get an 87-93 5.0 mustake fuel sock inlet screen and attach to pump to make it work . other then that the pump works great .
ghettosled
SYTY SUPERSTORE
Re: Walbro pumps
yeh but a gm wiring connector doesn't usually come with a mustang filter screen :)
the gm install kit comes with the smaller screen, thus the reason for machining the pump.
if you solder the wires, i guess it doesnt matter.
vinnieTy
TY # 1889
Re: Walbro pumps
Guys there has to be a walbro unit that fits right in without doing anything to it except take it out of the box it was shipped with and drop it in my tank. Is the one in the link the one to use with out any other items to buy?
BoostedSUV
Re: Walbro pumps
Vinny I bought my walbro from racetronix about 6 months ago. They offered a compete kit for the sy/ty... It was a direct fit, plug and play unit. I didn't have to modify anything. I also bought their Ty fuel pump "hot wire" kit which I recommend for every walbro install...
BoostedSUV
Re: Walbro pumps
Matt - thanks for the help!!! I just ordered the pump, wiring harness and the ground wire from your link. :tup:
Thanks
P.S any status with your truck????
Glad I can help, that's the best setup for our trucks and is the easiest most complete install :tup:
I've been busy, haven't really looked at my truck. I have a few more ideas for when I find some time. Running out of patience quickly though..
