Want to do A2A intercooler....need help!!!
Injected1
We'll I just bought another Syclone and I did a full tune up to it today. It's running okay but the W2A stock intercooler setup has been totally bypassed due to a leak. I have 2 other complete engines to get the parts to fix it and but I really want to clean up the engine bay and convert to A2A. Does anyone on this site have the assembly instructions from a McCoy FMIC or a new RPM FMIC. I want to do the stock location setup but I can do it myself for alot less than a kit costs. Anyone who can help I would greatly appreciate it.
Thanks, Nick
R&C_RallySyTy
Little Big Man
Re: Want to do A2A intercooler....need help!!!
We'll I just bought another Sylone and I did a full tune up to it today. It's running okay but the W2A stock intercooler setup has been totally bypassed due to a leak. I have 2 other complete engines to get the parts to fix it and but I really want to clean up the engine bay and convert to A2A. Does anyone on this site have the assembly instructions from a McCoy FMIC or a new RPM FMIC. I want to do the stock location setup but I can do it myself for alot less than a kit costs. Anyone who can help I would greatly appreciate it.
Thanks, Nick
I will follow this thread closely. I'll find some other threads and add them here for you.
Here you go: http://www.syty.net/forums/showthread.php?t=47633&highlight=A2A
Maybe someone else will chime in...good luck.
i have a mccoy kit that i havent installed yet but no instructions. but if you need pics, dimensions, measurements or anything let me know.
R&C_RallySyTy
Little Big Man
When choosing a A2A intercooler, keep in mind the choices you have. I'll list some of the things I know about A2A intercoolers.
Tube & Fin and Bar & Plate
So what is the difference you may ask?
Tube & Fin Pros
Weighs less than a similar bar & plate
Cheaper to produce
Common in OE applications
Tube & Fin Cons
Less flexibility in fin geometry designs
Leaks more than bar & plate designs
More susceptible to road damage
Tubes “balloon” under high pressure
Bar & Plate Pros
Wide variety of fin designs & greater design flexibility
Design works as a heat sink, which is Especially useful in stop-and-go traffic
Much less susceptible to damage, especially in front mount locations
Able to handle higher boost loads, depending on thickness of materials used
Bar & Plate Cons
Weighs more then Tube & Fin
More expensive to produce
Common in race applications
Injected1
I already know the intercooler I am using it is here..... http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=260266244939
My real problem is the removal and bypass of all the factory W2A and the way the brackets are located and made to attach to the frame.
Also the best option in routing the piping. I have seen many threads on here by many syty owners and all of the custom A2A kits are routed diffrently. I just want a clean factory look. This is going to be my daily car when I am not driving my company vehicle. And when I finally finish building "SYONORA" I will be selling my wife's Honda and she will drive the my daily. All this help is greatly appreciated!
thnks, Nick
JuStBlAzIN
thnks, Nick
I have a A2A dequick setup that mounts in the stock lower CCHE for sell. PM me or check out my for sell section.
