Wanted: Keyless Receiver for a 92 Typhoon
crariley
I'm looking for a functioning keyless receiver for my 92 Typhoon. This is the one with the two connectors. I found out the hard way that the receivers for the 93 Typhoons are not compatible.
DaveP
Re: Wanted: Keyless Receiver for a 92 Typhoon
You can make the 93 one connector module work in the 92 by re-pinning a couple of wires. You won't have the dome light supervision that the 92 has, because the 93 module doesn't support it.
I wrote a post with the required changes awhile ago. It may still exist. If you want to pursue using the 93 in the 92, and can't figure it out, PM me, I'll write it again. It's not that difficult.
atkonkler
Is this your bush?
Do what I did....get the oem part number and hit amazon or ebay.....you can program them yourself also. I ended up finding the gmc truck remotes that say it on them also.
crariley
Thanks Dave!! I'm traveling right now but will do some research when I get back home.
fivetodrive
CRISPY
I remembered this post and grabbed a 93 rke module when I was at the yard. Do you need one?
(Edit) should have read it closer, you wanted a 92...
If not I will be watching this thread because I would love to wire crispy up to have RKE!
crariley
I'm looking for a 92 RKE. If you come across one let me know.
