Wanted: Turbo Magicians
MAK
I am getting ready to start building up parts to do a 20g/14cm turbo and 2800 9/11 TC swap into my stock typhoon but want to have my used 20g turbo and housing gone through, cleaned, and refurbished/repaired (if repairs are needed). Could someone throw some reputable turbo rebuilders my way? I have seen some on here from the past (Waller, for instance) but I do know if they are still doing this type of work.
Thanks in advance.
nallj92
Re: Wanted: Turbo Magicians
I had a guy local to me do my 20g rebuild. The guy I used was in Burnsville, MN. Could also check around diesel shops close to you as well, they have the capabilities to order parts, rebuild and balance.
MAK
There is no one remotely close to me to do this so shipping it out will be required, unfortunately.
MAK
That is where my dad got the replacement stock turbo from. My 20g came from someone else. Their website says "Remember that we only service Forced Performance Turbochargers, DO NOT send in a turbo from another company for service or repair, it will be returned to you freight collect. No exceptions." so I figured I would look elsewhere.
TNPhoon
1of28
I've used this place twice:
Turbo Auto International Corporation
4403 Charlotte Avenue, Nashville, TN
(615) 383-6242 ‎
jeff@turboauto.biz
I know that the majority of his business (about 80%) is from out of town/shipped.
HTH
MAK
I went ahead and called Forced Performance anyway. Real nice guys. They will do it for me. Cost is starting at $410. I doubt my turbo needs a complete rebuild, but oh well.
TNPhoon
1of28
That seems kinda high IMO. Although, could just be because I have only used 1 shop, but here's what mine wound up costing:
Total cost + tax: $325.57
Cleaned and straightened shaft.
Bal shaft: 0.05-0.05
" " assy: 0.03 - 0.03
new service kit - bearings, seals, collar, blah blah blah
Polished shaft
Replaced heat shield
Blah blah blah
MAK
Hmm....yes, quite a difference. Add shipping and it gets expensive. I am hoping to get other options from here. Seems a shame that a topic such as "Favorite Fast Food" gets MUCH more attention than someone needing help.....:rotf:
I will give your place a call too. Thanks for the info.
TNPhoon
1of28
Change your title "BEWBIES INSIDE" and you'll have 20 responses in 5 minutes. :tup:
nallj92
http://www.dieselcomponentsinc.com/
these are the guys i used to rebuild my 20g. I needed a new impeller and that set be back a bunch~$150( true mitsu part) , otherwise they assembled it with a rebuild kit from mitsu and balanced it.
yes doesnt hurt to check around.
MAK
(615) 383-6242 ‎
jeff@turboauto.biz
HTH
I called them and Jeff said they would look at it and charge me according to what it needed. Sounds good. Thanks for the info.
BTW - Have a great birthday today, TNPhoon! Hopefully you can enjoy it and are off work (working on birthday = :tdown:)
TNPhoon
1of28
Sounds good. Lemme know how it turns out.
And thanks. But yep, workin. :tdown:
They probably just don't want to deal with Chinese eBay turbo's.
MAK
(615) 383-6242 ‎
jeff@turboauto.biz
I got the turbo back. It certainly looks nice - painted, polished, very clean. It cost $349. Evidently the oil had broken down and baked inside the turbo, shaft was slightly bent, insides replaced (seals, bearings).
Now if I could just get the old P.O.S. off I can put this on and be able to report on how it works.
Jeff was very easy to work with. Thanks for the recommendations.
TNPhoon
1of28
Great to hear!
I've had to use him twice...First one was to have the original rebuilt. Then to have it re-rebuilt because the machine shop plugged the feed line from the block to the turbo and being stupid, didn't check and verify that it was working properly. Anyways, my entire (first) rebuild was a complete cluster****. :rant:
Keep us posted on how well it works out for ya once on the bad-boy! :tup:
