Warning: Eagle rods/ARP bolts hit block:
UR50SLO
V6+2=LSXCamaro
WARNING:
Final assembly has started here and noticed as I spun the crank around the Eagle rods with the ARP 12pt bolts that it was close to the block.
#3 is hitting the block ever so slightly. I'll have to relieve the block. Anyone else have this trouble??????
Stock crank/SRP's/Eagle rods with 12pt ARP bolts is the combo.
Thanks,
Scott~
Re: Warning: Eagle rods/ARP bolts hit block:
you should have to modify the oil pan with a small ball pien hammer but not the block. or atleast i did'nt have to. i could see it with a stroker but not a stock crank. anyway just notch it and proceed with the install.
James Thomas
"NO CLASS"
Yea ditto on the dimple for the pan, never had a block issue and we do these all the time. Of course you can't put the crank in sideways though :rotf: .
__________
James
originally posted by mike lee @ rpm...
well if it didnt hit when you rotated the motor over, when would it hit? when the motor breaks in and the rods stretch?? for those of you worried, you should only be conserned about the oil pan clearance, as i have never had to clearance a block for the eagle rods w/ a non stroker crank.. never a bad thing to debur all the edges and aid on the side of caution, but it is certainly not needed.
ghettosled
SYTY SUPERSTORE
well we just did a motor and the block had to be clearanced.. guess there is a first for everything.. this is why we ALWAYS mock up a motor prior to final assembly.
0260IN3
Engine Builder
agreed. Every engine we build get clearanced on the pan and the block. My personal engine was clearanced and was still close upon inspection, so I clearanced it more before final assembly.
Deanzsyclone
I recall my block had to be trimmed a wee bit. I sort of remember it being that it was because of it being stroked?
UR50SLO
V6+2=LSXCamaro
My wife must be tight... Errr.. I mean her block must be tight.. Ahhh... crud..it's not going to come out right no matter how I say it. Lol..
Thanks for the interesting info. I was hoping someone had run into this before. I was not aware of the oil pan issue... I'll mock that up too.. Damn.. Be different if I was putting a stroker together. That's what we did back then on the 434small block we built. Lots of clearance issues.
Thanks again,
Scott~
Been years since I built a motor, and they've all been stock bottom ends anyway.
Curiosity question: How much clearance do you shoot for?
Comment/question: Should you also check the rod/cyl clearance as the crank goes past 90* or is that ever an issue with a stock stroke?
TIA
