I currently have the small, ultimate chip. After I got it a couple years ago, I went to Office Depot and when I came out, my truck wouldnt' start. hmmmm....., after trying a few times, I checked the chip, and it was on SEC. I didnt' put it there, as I just went in for a minute.
Below are a few excerpts from emails I sent to Todd regarding the symptoms:
I just happened one day. The problem is that I can't change programs, and as
of today, it randomly changes programs while I'm driving it. It moved from 115
to 116, to 118......til it finally upped to 320.....that's when I pulled over
to turn off the key, and by turning it back on (giving it power) it will
sometime cycle to next program....i did this til I was back on Val, that way if
it cycles again, it'll go to 115, 116, etc.....I don't want it to cycle to SEC
unless I do it on purpose and I dont' want anyone driving my truck.
Brian came over last night and we put the Ultimate chip in and tested
it....it started, and changed programs. This am on the way to work, I
was watching the chip and from the time I left my house until about 2
miles from work (8 miles total) and it switched programs by itself from
115 to 320....that's when I pulled over and turned off the ignition, and
cycled it through til I got to valet(I couldn't afford to get stuck in
SEC mode while driving). Then I started it and drove the last two miles
to work, it changed to 218 by the time I got there.
Bottom line, I sent it back, and Todd put a steel braided sleeve around the wiring harness, in addition to repairing suspect parts, and it's been working fine since. Seems to happen only with certain trucks.
Talk to Todd, he was great about getting me fixed up and running right.
