Waste gate crack pressure?
SYCLONE#1531
'MOFOFAST
Noticed a few problems at the track today. I couldnt get over 25lbs with the new 6766 cea turbo. Ive got the 38mm RPM external wastegate with the spring that came installed in it. 7 psi spring? I do have the adjuster tightened all the way in on the wastegate. Im running the AEM TRU boost controller with the crack preasure set at max 25.5lb wich I found is incorrect. Does anyone know the approximate crack preasure needed and sugestions on what spring to install to allow me to achieve aprox 30psi. The stocker ran 7.37 at 99 mph today 1.65 60ft at the uphill Paradise drag strip. This was my 1st time spraying 100% meth #8 nozzle,10 gallons of 93 octane mixed with 64oz of torco accelerator. , 28 degrees timing. Truck is looking very promising with the MPH...:D
TYTILIDIE
METH HEAD
Re: Waste gate crack preasure?
To make sure, you can run the line from the compressor housing to the top of the wastegate to make sure you aren't running out of turbo. Other than that, I am no help.
SYCLONE#1531
'MOFOFAST
I started with spring with no tention on it wich was only allowing me 21psi. Started cranking down on the spring and it picked up to 25psi. I dont think theres anyway I would run out of Turbo with the 67mm. I read that a boost controller can generally affectively double the wastegate spring preasure.
MIXEDBREED
Well I am running the same turbo as you so hopefully I can hit 100mph in the 1/8. I will be running 24-25 lbs with c16. Nice time by the way. A little better 60ft and your truck is in the 6's.
Agreed you are not running out of turbo. Unless you combo has changed (stock heads and cam) could the motor not be providing enough air flow?
RealFastV6
@jb_and_his_coffee
Re: Waste gate crack pressure?
On their site the only other option for the 38mm wastegate is a 12lb spring - which with the 4lbs of adjustment in the wastegate seems like it should get you there.
I agree you're pushing the wastegate open.
It's just a six
Super Member
A 7 psi spring is way too soft. 12 psi is still too soft.
I use a spring w/a base boost pressure of 15, adjustable to approx 20 PSI. I run 20-25 psi of boost.
I would install a spring w/a base boost pressure of 20 PSI.
If you have that , you would set the SPR mode @ approx 19 PSI, if you go over that on the SPR mode ,you will see the boost pressure surging.
Here is how to adjust the SPR mode. http://www.youtube.com/watch?v=aDzx2oW0cak&feature=relmfu
With a stiffer wastegate spring, you are going to see a BIG difference on how the turbo ramps up! Gotta watch for knock though.
If you know you are going to run 30 PSi, go w/a spring pressure of 25.
All of the vids
http://www.youtube.com/watch?v=8f5geWatdb4&feature=relmfu
http://www.youtube.com/watch?v=_iZBlFkasGE&feature=relmfu
http://www.youtube.com/watch?v=eZbxK9uPwnU&feature=relmfu
Your def not out of turbo especially with those highly restrictive stock cyl heads.
What meth kit are you using?
SYCLONE#1531
'MOFOFAST
Thanks for the info!!!!!:D
Heres a 10lb launch with the new SSM lift bars and front limiters!! FINALLY NO SQUAT!! Wow what a difference! Cant wait to get it to a nice sticky track!!!
SYCLONE#1531
'MOFOFAST
Thanks for the info..
Im using the coolingmist kit, works perfectly so far!
All of the vids
Aeroking
e.i.
you shouldnt run more than 2x the spring rating, above 2x you start losing the boost control. You can push it past 2x, but wastegate and controller manufacturers tell you to stay below 2x.
Damian
As far as the crack pressure, just play with it. If you have a 25psi spring, set the crack pressure at about 20psi. That's basically when the boost controller starts opening and closing. Then play with the duty cycle until you get the boost you want. It's kinda tricky to get it working the way you want, so don't be shocked if you set the crack pressure down to 15psi or so. For my stock setup, I have mine set at 4psi. And I get 14psi fairly consistently and quickly.
jpalmer
Your truck looks great in that pic. Sounds like you only need a stiffer spring
STAGEUP
You say you're on the stock long block right? Could it be that u may need stiffer valve springs?
SYCLONE#1531
'MOFOFAST
I dont think its that and yes its all stock lb. I just pulled the wastegate apart and found a large red spring which tial shows to be 11.6. It was pushing open at 22psi with know tension on the spring. With tension it went up to 25psi. Im going to order some more springs monday from precision to get the base preasure around 20psi. This should keep it shut!
http://www.youtube.com/watch?v=X-bLTH69SD8
It's just a six
Super Member
If you want the quickest spool-up from the turbo, you set the SPR mode on your TRU boost controller close to what your base boost spring pressure is on your wastegate.
You will know if the SPR mode is set too close or over your base boost pressure,,, your boost pressure will surge , just like in the video links I posted.:tup:
Having an electronic boost controller trys to open up the wastegate at the very last possible moment, if you set it for 25 psi, it will try to keep the wastegate close until it sees close to 25 psi.
A manual boost controller cannot even compare to an electronic boost controller.
I have run up to 26 psi & no valve float, the stock GN's & T-Types have problems w/soft valve springs.
SYCLONE#1531
'MOFOFAST
Im taking it to the Silver Dollar dragway tommorow. Just got everything back together a few minutes ago. Done one run and it seemed to run pretty good, Still slowly adjusting boost upwards.. now at 23.5 at 35% duty cycle. Im gonna keep tuning it tonight until ive got everything where it needs to be. Wastegate is now dumped to atmosphere.. One + is im now building boost on the brakes really fast. Must be the new springs? From what I can tell. Im running a large red spring 11.6 with a small blue spring 8.7 which comes in at 20.3lbs. base. It was surging at spr 21.5lbs. I guess ill drop it back down until it goes away.
Sean Krupa
Moderator
Just out of curiousity, do you have any pics of your new Wastegate setup to atmosphere? Looking forward to seeing some more vids and times tomorrow, Good luck!
It's just a six
Super Member
Yep, the stiffer springs will allow the engine to build boost quicker.
Yes also on the SPR setting. if your base boost pressure is 20.3, the SPR will need to be set lower than that, approx 1-2 psi less as a rough esttmate. So try 18.5 & try it out to see if surge goes away, then if all good, bump up the SPR mode a little bit @ a time.
Goodluck @ the track & you will see the boost comes on way stronger than before w/the softer wastegate springs.:tup:
SYCLONE#1531
'MOFOFAST
Open wastegate sounds like a swosh sound on my truck when it opens. So far Very pleased with the sound.
Welded capped so that it can be opened again if needed. RPM downpipe.
