Waste gate noob help
Fitos
Getting a f38 waste gate for dirt cheap do you guys recommend using a 38mm on a stock setup?
RealFastV6
@jb_and_his_coffee
Re: Waste gate noob help
There's no provision at all for an external wastegate on the stock setup, and the stock internal wastegate is sufficient for the stock turbo.
Ross L
putting one on my stock truck. Got rid of the cat, guess what happened. I figured a external gate would "cure" my issue. NOT putting cat back on.
Fitos
so external will fix catless over boost isue then any one else done this?
Ross L
Yes, just wire stock gate shut(is that even necessary?) and add external gate to crossover. I bought a crossover with a flange already welded on from a forum member. Now external gate controls boost, no more overboosting:D
