Is there a clip that holds the arm onto the wastegate pin? I discovered that the arm became disconnected, for how long I dont know. Only running 6 lbs of boost max, until I hooked it back up, but then the arm popped off again.
I use the little bobby pins that you find holding the Lexan body on an R/C car/truck. Works good and much easier to grab than those stupid "E-clips" that go flying into no-man's-land when they finally pop loose!
