Re: wastegate actuator spring pressure
DAQ are you guys talking the amount of boost to first move the WG or the actual amount of force (meaning pounds of force applied to the WG actuator rod) it takes to first move the actuator?
Thanks
The amount of pressure applied, via boost pressure, to the wastegate at the point to where the wastegate begins to open. Say the wastegate will give you 7psi, it will actually begin to open at say 6psi. Every wastegate is different. Getting that setting correct will help prevent boost spikes with the TruBoost.
Atkonkler, it just delays the time the boost solenoid stays closed. The solenoid stays closed till it sees that pressure you set as crack pressure, then it opens and closes according to yiur duty cycle you have it set at. Just work your way up in .5 psi increments until you start to see a spike in boost pressure (when boost goes up). You want to adjust it so that you hit, let's say 14psi and holds there. You don't want it to go to 15psi and then drop back down. You want it to hit 14 and then stay there.
